SEA WATER COOLING SYSTEM INSPECT
Hi, in this moment i have to develop an inspect program to our cooling system, the system is based on a pipelines that conduct sea water to cool our compressors and other stuffs, the pipes are  internal coating with pe and cml liners and external with pe, the pipeline is built from  cs tubes. the diameters varies from 120" o.d. to 6"
i would like to know where can i find the major damage, because the system is big and is not practical to inspect all.
the pressure are from the 1 bar to 4 bar and the temperature is from  30 to 45 c deg.
i will appreciate all help that you can give me, im new in this department.
best regards.
luis e. carrera anlehu
