Underground Building.
Hello all;
I am designing an underground building which has a length of 200 feet and width of 60 feet. The height of the walls is 29 feet and it will have a dirt cover of 3 feet (The slab will see 3 feet of dirt). EFP pressure from the geo-report is 50 pcf/ft. Seismic is 15 H (inverted triangle). Surcharge is around 100 psf, first ten feet. No groundwater is present.
Per the architect, we are not allowed to put any columns in the middle of the building. So we decided to put columns only around the perimeter, 20 feet on center.
My question is the following;
I will be using a special reinforced concrete moment frame, has anyone design this type of building using a different system?
Thanks.
Thanks.
RE: Underground Building.
Dik
