Twisted tubes heat exchangers
I would appreciate your suggestions in finding suppliers of twisted tubes. I know that Brown Fintubes/Koch has the patent to produce them, but I've heard that there are are suppliers too, therefore they are no longer protected.
RE: Twisted tubes heat exchangers
The only supplier with engineering and design experience is Brown.
In non-US markets there may be people copying the look, but they will have little knowledge of the engineering.
Plymouth Tube
I have nothing against buying from Brown, but they are not willing to supply the tubes only and since I am bidding for a repair work I look for other sources, possible other licensed producers. Thanks for suggesting Heseman. I will contact them. What about suppliers in Europe ?
KALEM09, you might try Delta T Limited, www.deltatlimited.com/
Mike
