Help with ideas for cooling system...
I'm working on a test stand for items of plant that are usually submerged in cold, fast moving water.  They have a cooling demand of between 36kW and 900kW, and vary a lot in shape and size.  Assuming that we can't just plumb directly into the onboard heat exchangers, what can we do to cool this kit on dry land?
Thanks for your time,
Pete
RE: Help with ideas for cooling system...
Use the air cooler mentioned in your previous post.
gr2vessels
