UGS NX CAM Postprocessor
Hi everybody
I've got some problems with my post processor. I do believe, that you can help me.
1st problem is that post do not put automatically cutcom adjust register D when the cutter compenstation is used. To make G-code correct, I have to turn the compenstation ON in machine control. Is it possible to make the post put this D register just exactly as the tool number, not to make it manually. (Custom command?)
2nd problem is based on rotary axis limits. How to make mirrored fourth axis coordinate if it greater than 0. I mea n if it is A23. by default, it should be posted like A-23. B180. Other words, the rotation of the fourth axis must be always at negative side.
I am glad to read any helpful information
With best regards
Yuri
