Rating of MCB
Rating of MCB
Rating of MCB
I have to add additional circuit in the existing control circuit. the additional circuit involves some wiring & MCB. The control supply is 230 V ac. How it will be decided that what would be the rating of MCB.THe existing wiring used is 2.5 sq mm.
thanks
RE: Rating of MCB
Hi.
1. Load and type of load. Choice of MCB curve : A,B,C,D,K,Z
2. SC on this additional wiring.
3. Selectivity with upstream MCB.
4. Selectivity between upstream MCB ( or MCCB) and new one according to MCB types.I would recommend check table of selectivity of MCB mnf.
Good Luck.
Slava
