Any way to effectively outline the surface(s) that intersect a sketch
plane?
For instance, if you open a sketch on a flat surface with complex edges, is there a tool that will draw the outline of that surface automatically?
The problem is that I've created a full-round surface fillet and have intersected it with a plane at a different angle. I need a sketch to match that curve exactly, but I'd rather not do the math myself.
Thanks!
Thanks!
RE: Any way to effectively outline the surface(s) that intersect a sketch
Offset Entities with 0 offset. :)
