100% OA Coil Load
100% OA Coil Load
I have a room that calls for a 100% OA heating only system. The room is 20 x 20 and i'll be sending in 10 AC. My question is do I take the building envelope heat losses into the calculation or do I just calculate the BTU needed to bring the OA temperature up to say 90 degrees and that will be enough. Why would I include the envelope losses if those losses aren't being seen across the coil and only the OA is?
RE: 100% OA Coil Load
