Aesthetically pleasing NEMA 4 X boxes
I am still looking all over creation for an off the shelf(i.e. not custom) readily available die cast aluminum die cast box.
I have got some samples in from Hammond, pacific wireless, etc and they are all either too flimsy or art butt ugly.
I am looking to get something that has some aesthetics to it and can render some "brand" recognition. Anyone know a rep that makes die cast aluminum enclosures like this? It has to be a casted part.
Phil
Phil
RE: Aesthetically pleasing NEMA 4 X boxes
Brand recognition = custom
The Hammond stuff is ugly. Pomona makes some boxes that look sort of nice. Rose enclosures may have something.
Drawoh's rules of styling
- If you want it to look good, it is going to cost more. You are using a more expensive fabrication process, more expensive materials and finishes, and/or you are compromising assembly and service access.
- Keep it simple. You are not an artist. You are not qualified to be crazy.
- Bad styling looks much worse than unstyled, functional.
Rule 1 is the most important. You need to try out several approaches. Show your boss how good it will look and tell him the cost and risk of achieving it. Let management make a decision. Your marketing department might step in and surprise everyone.RE: Aesthetically pleasing NEMA 4 X boxes
I actually have a sample coming from Rose Bopla. I've been on Pomona's site too.
I am trying to get a quote from Hubbel Killark on their NEMA 4 box from the E3 catalog page. Does anyone know a good distrubutor in the south east that can supply one of these. The local rep i work with here is not getting back to me fast.
phil
One time I needed to punch a lot of fancy connector holes in the lid, so they allowed me to order the deep box without the cover. I then supplied my own flat sheet metal cover that just fastened onto the deep side of the box. That worked out fairly well.
See: http://www.budind.com/die_cast_boxes.shtml
