Small DC Pump
Small DC Pump
Small DC Pump
All,
I am working on an application/product where I would like to use a small DC (6V) pump, capable of < 1/2 GPM flow, with about 5' of head.  I have looked at some aquarium pump manufacturers, but they are all 110 VAC.  This application is going to be remote battery operated with solar trickle charging, intermittent operation.  Any suggestions would be helpful.
Rich.....viking2
Richard Nornhold, PE
http://www.ovenind.com
RE: Small DC Pump
nornrich,
   Search Micropump's website and catalogue.  You should be able to find this stuff on Google.
               JHG
RE: Small DC Pump
I'm certain there is nothing like that available in the recreational marine world.
RE: Small DC Pump
Forget Micropump- you only need 5' of head.  Try a recreational vehicle bilge pump- probably more flow than you need at 12V, but at 6 volts it might just work.
RE: Small DC Pump
Does this fit?
http://www.siliconsolar.com/replacement-6v-solar-pump-p-102.html
- 6V
- $15.95
I happened to be working similar problems (sitting for the P.E. this month).  I've attached an excel worksheet for you to play around with if the numbers change a bit.
http://files.engineering.com/getfile.aspx?folder=f9a3472d-45c7-4f81-9cbf-9066c256094d&file=hp_from_head.xls
Inputs (in yellow): head required, voltage, GPM, pump efficiency, specific gravity.  It calcs things like:  mass flow rate, Watts required, hp required, amperage required, and wire size to go with the particular load.
I just wanted to make sure you could get 5 feet of head from the 6 volts. Of course, it depends on the current, so you can see that the current draw isn't too bad 78mA requiring 32 gauge wiring or better.
RE: Small DC Pump
DarrellThomasNV,
Thanks.  This is exactly what I was looking for.  Good luck with the PE exam.  One word of advice, take along a bottle of Excedrin and/or Tylenol, because afterwards you are going to have a headache.
Rich.....viking2
RE: Small DC Pump
Great news! passed the P.E. exam.  Now just need to find one more Mechanical P.E. reference!
dt
RE: Small DC Pump
congrats Darrell!
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Small DC Pump
Congrats, Darrell!!  Now pucker up the first time you sign/seal something!
RE: Small DC Pump
Thirty years later and I still pucker.....
