How to insert a filament into tire
I would appreciate any ideas regarding a way to insert a U-shaped metal filament into the inside of tire.
How to insert a filament into tireHow to insert a filament into tire(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: How to insert a filament into tire
Dan - Owner
http://www.Hi-TecDesigns.com
To start with, where do you want to place this U-wire? Inside the tyre's cavity or within the tyre's structure?
The shape of the pin could possibly be a U-shaped pin with the base on top (that is an inverted "U") and the bottom ends would be flush with the inner surface of the tyre. The U shape would almost look like two "I" letters, connected at the top.
What I am actually asking is for a tool or method to introduce such a pin into the tyre. I hope my description is clear. Please feel free to ask for more clarifications.
Any metal pin introduced in this way would also need to be brass plated to allow a bond to form between the metal of the pin and the rubber. Next the pin must pass through textile and steel cords without damaging the cords or the pin. Finally, such an installation, even though it would be very light weight, could possibly cause problems with the static and dynamic balance and the radial run out and radial force harmonics within the tyre.
How do you propose for the signal from the control box to be carried to the indicator lights?
