NX4 - How do you show hidden lines of a solid body in draft
NX4
I have an assembly made of solid bodies. Is there a way to show the hidden lines of a specific solid body or layer in the draft?
RE: NX4 - How do you show hidden lines of a solid body in draft
Yes
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Okay well I suppose you'd like to know what it is. What version are you using by the way?
Look under Preferences>Drafting for the View Tab and near the bottom is something called "Define Render Sets". You use that to elect how individual bodies will appear when the named render sets are activated using view style.
That is the short explanation. Hitting F1 for help may offer a more comprehensive version.
Best Regards
Hudson
www.jamb.com.au
Do you tell me how?
I was posting to two guys and hit submit on your topic without initially supplying the answer. You'll find the second post more helpful wink
Best Regards
Hudson
www.jamb.com.au
