Convert to sheet metal from solid shell
trying to convert solid shell to sheet metal feature, i'm getting an error "The selected body does not have any geometry..... " that am i doing wrong?
see attached pdf and prt files.
thank you
thank you
RE: Convert to sheet metal from solid shell
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX6.0.3.6 MP2 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
the sheet metal model is ok now. but why it is not working with chamfers? or maybe there is one more way to solve the problem (i mean, not to use "convert to sheet metal" function)?
Other times you can add features after you convert the model to sheet metal and then add the flattening to get the same results.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
now one more question again. why it is not possible to create "closed corner->circle cutout" feature in area B (see attached pdf file)?
Best regards
www.jcb.com
and one more question. how can i define bend radius? in customer defaults there is value 2mm, but after converting to sheet metal bend radius is 3 mm. and convert to sheet metal feature dialog hase bend relief option. but you can enter any value there, but no effect. why?
NX 4.0.4.2 mp10
win xp+sp3 32 bit
