flow rate in pipe from a storage tank
I have a storage tank with oil elevation as 20m.A pipeline flows from the bottom about 500 m long and I want to know the discharge rate at the exit of that pipe.This can only be done if I know the discharge velocity.I am applying Bernoulli equation on the pipe exit point and tank top. Can I assume that the pressure at the exit of the pipe would be atm.If I don't do this then there are lot of unknown variables in the equation. In my opinion it might not be atmospheric because there will be some pressure inside the pipe on top of the atm pressure even though I am taking into account the losses due to friction and velocity head etc.
RE: flow rate in pipe from a storage tank
Cheers,
John
Or dig deeper and determine the dynamic and kinemtic viscosity to calculate the Reynolds number enabling you to determine the type of flow either lminar or turbulant which will lead to your flow rate.
I agree their are always so many variables, the inside roughness of the pipe, but viscosity in centistokes is important
Always best to check your basic references first. This way you become educated on the problem, you have learned something, and you have learned your references better. All of these benefit you in the future. It's a win-win for you.
