Nt services - schedule is not listed, we want to add
On my NT4.0 Server and in the services window I do not see the service (schedule). How do I go about loading this service? Our NT System =(NT 4.o service pack 6).
RE: Nt services - schedule is not listed, we want to add
Investigate first the service is not working due to some system problem, or due to login account restrictions. Once you are sure that it is not due to these problems, proceed.
You will need administrative right to perform these.
There are two possible tools which could help you.
DOS based "instserv.exe" does nothing but add the executable for scheduler as a service. Look at the different options by using the /? (help) switch.
Second one, GUI based "srvinstw.exe" is more user friendly and can specify the user accounts to be used to start the service. Make sure it is system as the Scheduler need to be an administrative service.
You can find both these executables in the NT4.0 resource pack CD.
