BOM Quantities
BOM Quantities
BOM Quantities
I have an assembly with a family table. The instances are accessories to the main assembly. I created a drawing with the main assembly view and two views that show the accessories. There are (4) .375 nuts used in the main assembly view and (1) .375 nut used in one of the accessory views. I have a BOM set up with 3 repeat regions for the 3 views. My problem is the repeat region for the accessory shows a quantity of (5) .375 nuts. I want to show a quantity of (1) for this accessory view in this repeat region. Can I do this? If so how? TIA for your help.
RE: BOM Quantities
Make a simpl rep of the assembly with only one nut showing, the other 4 are not shown. In the Repeat Region, select to replace the master model with the simpl rep version of one nut.
Steve
http://www.3dlogix.com
