Help needed - Problem in generating a solid
I am trying to create a solid in the assembly section, but I am running into these errors - "The depth reference should not be on the section plane" and "Could not determine feature depth.
   #QUICK FIX, #REDEFINE/#REROUTE"
The same technique worked before, so I am clueless what is going wrong. Any suggestions ?
I am trying to generate a solid (PRT0003) using sketch 1. I want this solid to exactly fill in the hole in PRT0002. I am attaching the assembly file.
SS
