Maximum Reinforcing Pad thickness
As per ASME Scetion I/ Section VIII, is there any limit (Min or Maximum) on the thickness of reinforcing pads one can use?
RE: Maximum Reinforcing Pad thickness
As far as I know, it just has to be within the limits of reinforcement that are calculated per the code rules.
As far as I know there is no minimum as long as there is adequate reinforcement.  The reinforcement doesn't even have to be an added pad - it can be inherent to the material with the opening.  For limits regarding the thickness that can be included in calculation:
For Section 1 check out PG-36.3
For Section 8 look at UG-40(d)
TechThrm,
          For reinforcing pads the maximum thickness for which you can take allowance for is 1.5 times the pipe/vessel thickness.
Thank you Guys.
DSB123, can you give me the some reference for "reinforcing limit on pad being 1.5*pipe/Vessel thickness".
