Relief Valve Inlet Pressure Drop
When did the ASME Section VIII Division 1 Code add the specific 3% limitation on the inlet pressure drop to relief valves in Appendix M?
RE: Relief Valve Inlet Pressure Drop
I show it in an old relief valve catalog in 1990, so prior that.
