Isometric Drawings of Parts in MS Word
I would like to put simple line sketches of parts in an MS Word report.
I want a lossless file that looks similar to the pdf with sharp lines.
How can I do this, I can first convert it into a drawing with no title block but then what shal I save it as? Shal I use the edrawings program?
Thanks, Chris.
Thanks, Chris.
RE: Isometric Drawings of Parts in MS Word
Eric
http://www.EsoxRepublic.com-SolidWorks API VB programming help
GhostScript is a PostScript converter. If you can save PostScript, embed the PostScript into your MS Word document. PostScript meets the OP's requirements exactly.
Set up a PostScript printer and print to disk.
-- MechEng
Thanks for the help guys :)
