Distance between pump suction intakes?
I am installing two vertical 10000 usgpm centrifugal pumps in a salt water well (13'x 22'x 20' deep). The pumps were purchase second-hand and I have limited information on them.  Due to constraints, I may have to put the intakes of the pumps about 6.5' apart. I am concerned that since the intakes of the pumps are relatively close together it may affect their performance.  Does anyone have any suggestions?  Thanks.
RE: Distance between pump suction intakes?
Hello x926e
The rules of thumb that I use for multiple suctions in a well are:
1. The centerline distance between two pump suctions should be equal to at least 3 x the diameter of the suction bell opening.
2. The centerline of a pump suction should be at least 1.5 x the diameter of the suction bell opening away from any vertical wall.
3. The bottom edge of the suction bell opening should be at least 0.5 x the diameter of the suction bell opening off the bottom of the tank.
I hope this helps you
Fredb
do you happen to have the ansi/hi-9.8-1998 standard, if so do you have any equations giving the above stated requirements.  if so that would be great.
Any good pump book will give you the information you are looking for including the correct distances for the pump inlet to be positioned from the floor and from the side walls of your sump. You may also need to address some sort of vortex breaking device incorporated into the sump if the pumps are prone to pre-rotation of the inlet flow.
International College
Naresuan University
Phitsanulok
Thailand
fredb,
I can't believe your post has been sitting out there for two years and never got a star.
I just fixed that.  Excellent information.
rmw
