Asymmetrical Loading of Helical Spring
I have two discs clamped together by a helical spring. Pressure is applied to a semi-circular area between the discs. As a result, the separating force is not applied uniformly around the circumference of the spring. Is there a way to calculate the pressure at which the discs will begin to separate?
Thanks.
Thanks.
RE: Asymmetrical Loading of Helical Spring
What I'm really after is how to predict load and deflection for a helical spring that is asymmetrically loaded.
Thanks.
Thanks.
