environment file
environment file
environment file
Hello, does anyone have an updated environment file I can take a look at that works for abaqus version 6.8.
We ugraded from v6.7 and I get the following error when I try to run a program with my existing env file. Attached is my old env file. Any idea what I am missing?
I get the error when i run it with the old env file:
Traceback (most recent call last):
  File "Python/driver/driverEnv.py", line 248, in envRunFile
  File "/share/roshoge/abaqus_v6.env", line 156, in ?
    mp_mpirun_path = {HP: hpmpipath,
NameError: name 'CRAY' is not defined
Thanks!
Rich
RE: environment file
#        System-Wide Abaqus Environment File
standard_parallel = ALL
mp_mode = MPI
mp_file_system = (DETECT,DETECT)
mp_environment_export = ('MPI_PROPAGATE_TSTP',
                         'ABA_CM_BUFFERING',
                         'ABA_CM_BUFFERING_LIMIT',
                         'ABA_DDM_DEBUG',
                         'ABA_DMPSOLVER_BWDPARALLELOFF',
                         'ABA_ELP_SURFACE_SPLIT',
                         'ABA_ELP_SUSPEND',
                         'ABA_HOME',
                         'ABA_MEMORY_MODE',
                         'ABA_MPI_MESSAGE_TRACKING',
                         'ABA_MPI_VERBOSE_LEVEL',
                         'ABA_PATH',
                         'ABA_RESOURCE_MONITOR',
                         'ABA_RESOURCE_USEMALLINFO',
                         'ABAQUS_LANG',
                         'ABAQUSLM_LICENSE_FILE',
                         'ABQ_CRTMALLOC',
                         'ABQ_DATACHECK',
                         'ABQ_RECOVER',
                         'ABQ_RESTART',
                         'ABQ_SPLITFILE',
                         'ABQ_XPL_WINDOWDUMP',
                         'ABQ_XPL_PARTITIONSIZE',
                         'ABQLMHANGLIMIT',
                         'ABQLMQUEUE',
                         'ABQLMUSER',
             'CCI_RENDEZVOUS',
                         'DOMAIN',
                         'DOMAIN_CPUS',
                         'FLEXLM_DIAGNOSTICS',
                         'FOR0006',
                         'FOR0064',
                         'LD_PRELOAD',
                         'MP_NUMBER_OF_THREADS',
                         'MPC_GANG',
                         'MPI_SOCKBUFSIZE',
                         'MPI_WORKDIR',
                         'MPCCI_SERVER',
                         'MPCCI_INITIAL_EXCHANGE',
                         '_MPCCI_CCM_CODE_IDS',
                         '_MPCCI_CODE_IDSTRING',
                         'ABAQUS_CCI_DEBUG',
                         'NCPUS',
                         'OMP_DYNAMIC',
                         'OMP_NUM_THREADS',
                         'PAIDUP',
                         'PARALLEL_METHOD',
                         'RAIDEV_NDREG_LAZYMEM',
                         'ABA_SYMBOLIC_GENERALCOLLAPSE',
                         'ABA_SYMBOLIC_GENERAL_MAXCLIQUERANK',
                         'ABA_ADM_MINIMUMINCREASE',
                         'ABA_ADM_MINIMUMDECREASE')
compile_cpp=['cl', '/c', '/nologo', '/W0', '/MD',
             '/TP', '/EHsc', '/DNDEBUG', '/DWIN32', '/DTP_IP', '/D_CONSOLE',
             '/DNTI', '/DFLT_LIC', '/DOL_DOC', '/D__LIB__', '/DHKS_NT',
             '/DABQ_NTI_NET', '/DFAR=', '/D_WINDOWS', '/DABQ_WIN86_64',
             '/O1', '/I%I']
compile_fortran=['ifort', '/c',
                 '/DABQ_WIN86_64', '/nologo', '/include:%I']
link_sl=['LINK', '/nologo', '/INCREMENTAL:NO',
         '/subsystem:console', '/machine:AMD64', '/NODEFAULTLIB:LIBC.LIB', '/NODEFAULTLIB:LIBCMT.LIB',
         '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:LIBIFCOREMD.LIB',
         '/DEFAULTLIB:LIBIFPORTMD.LIB', '/DEFAULTLIB:LIBMMD.LIB',
         '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib',
         '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib',
         '/FIXED:NO', '/dll', '/def:%E', '/out:%U', '%F', '%A', '%B',
         'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib',
         'advapi32.lib']
link_exe=['LINK', '/nologo', '/INCREMENTAL:NO',
          '/FIXED:NO', '/LARGEADDRESSAWARE', '/out:%J', '%F', '%M', '%L', '%B',
          '%O', 'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib',
          'advapi32.lib']
# Link command to be used for MAKE w/o fortran compiler.
# remove the pound sign in order to remove the comment and have the file take effect.
# link_exe=['LINK', '/nologo', '/INCREMENTAL:NO',
#          '/subsystem:console', '/machine:AMD64', '/NODEFAULTLIB:LIBC.LIB', '/NODEFAULTLIB:LIBCMT.LIB',
#          '/DEFAULTLIB:OLDNAMES.LIB', '/DEFAULTLIB:MSVCRT.LIB', '/DEFAULTLIB:kernel32.lib',
#          '/DEFAULTLIB:user32.lib', '/DEFAULTLIB:advapi32.lib',
#          '/FIXED:NO', '/LARGEADDRESSAWARE', '/out:%J', '%F', '%M', '%L', '%B',
#          '%O', 'oldnames.lib', 'user32.lib', 'ws2_32.lib', 'netapi32.lib',
#          'advapi32.lib']
# MPI Configuration
mp_mode = THREADS
import driverUtils, os
mp_mpi_implementation = NATIVE
mp_rsh_command = 'dummy %H -l %U -n %C'
mp_mpirun_path = {NATIVE:'C:\\Program Files\\Microsoft Compute Cluster Pack\\Bin\\mpiexec.EXE',
          HP:'c:\\Program Files (x86)\\Hewlett-Packard\\HP-MPI\\bin\\mpirun.exe'}
if os.path.exists(mp_mpirun_path[NATIVE]):
    mp_mode=MPI
    run_mode=BATCH
    from queueCCS import QueueCCS
    queues['default'] = QueueCCS(queueName='share', requireShareSubmit=1)
    queues['share'] = QueueCCS(queueName='share', requireShareSubmit=1)
    queues['local'] = QueueCCS(queueName='local', requireShareSubmit=1)
    queues['genxmlshare'] = QueueCCS(queueName='genxmlshare', requireShareSubmit=1)
    queues['genxmllocal'] = QueueCCS(queueName='genxmllocal', requireShareSubmit=1)
# Delete/comment the following two lines if MS MPI is the preferred default
if os.path.exists(mp_mpirun_path[HP]):
    mp_mpi_implementation = HP
graphicsEnv = driverUtils.locateFile(os.environ['ABA_PATH'],'site','graphicsConfig','env')
if graphicsEnv:
    execfile(graphicsEnv)
else:
    raise 'Cannot find the graphics configuration environment file (graphicsConfig.env)'
del driverUtils, os, graphicsEnv
abaquslm_license_file="27000@blaprocrdc238"
doc_root="http://ROCSTUPPLRKXP03:2080/v6.8"
abaqus_no_hardware_acceleration=ON
#max_cpus=6
#scratch="E:\temp"
ask_delete=OFF
def onCaeStartup():
    def setVisPreferences(module,userData):
        import visualization
        session.defaultOdbDisplay.contourOptions.setValues(
                   renderStyle=FILLED,visibleEdges=EXTERIOR,
                   contourStyle=CONTINUOUS,
                   minAutoCompute=OFF,
                   minValue=0)
    addImportCallback('visualization',setVisPreferences)
Rob Stupplebeen
