Multiple leaders from one note?
3
Howdy all,
Is there an easy way of doing multiple leaders from one note?  If I want a note to point to two different things on a drawing I usually just add a dummy note with a space and move the leader to where I want it, but if I move a note only it's real leader moves with it.  I've got to move the other leader seperately.
Not a big deal, I was just wondering if there was some simple switch I was missing.  SW2009 and I have been working with SW for about 3 years now.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
RE: Multiple leaders from one note?
Kirby,
Select your note and then control-drag the leader to create multiple leaders.
Easiest way is to Ctrl-select the elements to which you want the leaders attached, then activate the Note tool and place the note.
If the note is already placed, click on the arrow, then Ctrl-select the square at the tip of the arrow and drag and drop.
Wow,
Simple, straight forward.  I spend a couple of hours trying to figure that out before I went to the experts.  Thanks dgowans.
-Kirby
Kirby Wilkerson
Yet another way.
1. Select Note Icon.
2. Move your mouse cursor to the position where you want to place the note.
3. Hold down CTRL (but dont click yet). This will freeze the position of the note.
4. Without releasing CTRL, select multiple entities one by one
Well, I'll be dipped in...    ...never mind.
Is any of that in SW's "help"?  Or Tutorials?
Mike Halloran
Pembroke Pines, FL, USA
Mike,
Yes this info is in the SolidWorks Help.
Do a Search on 'multiple leaders'
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2009 SP3.0, Windows 7 RC1
http://www.solidmuse.com
http://www.phxswug.com
Okay, that's ... one in a row.
Thanks.
Mike Halloran
