Critical flow calculations -- proper fluid properties
Hello, I have done numerous critical flow calculations for both restriction orifice sizing and tube failure scenarios. I have typically based my calculations on those in Crane's handbook, using upstream properties (density, pressure) to calculate maximum flow. I was recently given an equation to use that appears based on sonic conditions (at P2 as calculated by critical pressure ratio) instead of upstream conditions; I have never seen the equation or used it, and as it obviously will generate a lower flow at the lower pressure and density, am reluctant to consider it an appropriate basis for my calculations. However, I don't want my calculations to be needlessly conservative.
Has ANYONE ever heard of or used conditions at critical flow for calculating flow through an orifice?
RE: Critical flow calculations -- proper fluid properties
David
