Instantiation
Instantiation
can anyone tell me how to multi-instantiate parts of a product in 2 axis. I can achieve this in 1 axis but can not detrmine how to control the co-ordinates in the other axis.
Di i have to input a ratio?
RE: Instantiation
RE: Instantiation
I played around with it some more and found that by adding a line between the two points, in this case the rise and run of a stairway, I could enter the distance as the length of the line and select the line for direction.
Seems to me it would be a lot easier if it was possible to just enter the values for each axis.
RE: Instantiation
Max
