Recommended Sources for Aluminum Extrusion, Anodizing?
I've got a small part that's cut from an extrusion and needs anodizing that I need to source. This is primarily a cosmetic piece, so the anodizing quality is more important than the strength of the part. Preferably I could obtain a chamfer on the edges of the part during the cut-off process (round extrusion chucked into lathe, cut to length).
Can anyone recommend a good source for this sort of operation? I figured I'd check here first for a solid contact rather than try anyone I could find on the Internet.
Thanks!
Thanks!
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
RE: Recommended Sources for Aluminum Extrusion, Anodizing?
IHC
www.ihccorp.com/
Pioneer Metal Finishing
www.pioneermetal.com/
