Install difficulty with Machinery library.. NX6
The install appears to hang on "Loading Libraries"
I don't really understand the first portion of the install instructions... maybe I'm falling down here.
Should I be placing the downloaded data in a specific folder for the install process?
See indtructions below...
"The machine to run this install must have NX5.0, NX5.0.X or NX6.0 installed.
The zip files for each desired library must be copied to the "${Installation_Tool_Root}\Tool\libs" folder. No need unzip files.
This tool doesn't support in net path."
RE: Install difficulty with Machinery library.. NX6
FYI... I didnt pay enough attention and needed to down load the indvidually zipped fastener libraries.
I had this same problem but no access to the individual zipper fastener libraries.  Does this reuqire a special license?  Has anyone else had this problem?
