Operating Curves For generators
I want to draw operating curves for gen which will determine the max out put f the gen keeping in view the temperatures f stator and rotor and also the satbility limit of the gen is not crossed.Can some one give me an easy way as the books description is a lengthy one
RE: Operating Curves For generators
Can you post the name or title of the document so we could do a search for it?
rmw
Or just zip it into two parts. I wouldn't mind having a copy as well Scotty.
Maj
It's a scan of a paper copy I was given by an old friend. It simply ain't out there on the net - I've looked long and hard for the CEGB archives. There are probably hundreds of top quality technical documents lurking in desk drawers and files belonging to retired CEGB engineers throughout the UK which one day will be lost forever because they are only in paper form.
OK, it's on rapidsahre for a while...
http://ra
Fantasic document, i will have to dig my old design notes out, our system was a lot simpler (but perhaps not as accurate. As the documant says, if your concern is the lagging (overexcited) area, then it is quite simple, the leading area is a lot more complex.
I too couldn't download the CEGB document.
'Rapidshare' has restrictions for free upload/downloads. 'Mediafire' is better I think.
jan63:
The CEGB document is very detailed but the contents quite difficult to handle. Fortunately there is a far simpler but still very accurate version for the design of generator performance charts available. This is illustrated on page 20 in "Betriebsverhalten der Synchronmaschine" by Kurt Bonfert, published in 1962 by Springer-Verlag/Germany.
We have to consider two different versions of generator performance charts, one is valid for turbo generators (with cylindrical rotors) and one for salient pole machines (hydro generators). The difference lies in the values of the synchronous reactance. For hydro generators we have a direct axis synchronous reactance xd and a quadrature axis synchronous reactance xq (the xq value is about 60% to 70% of the xd value) whereas for turbo generators both values are about the same (xq = xd).
Let me know in case you have no access to the book mentioned above. I'll then try to draw up for you the two types of charts.
Scotty: Thanks for sharing with us a valuable part of your archive.
Wolf
WWW.HYDROPOWER-CONSULT.COM
Scotty, I believe you have an email address for me, could you email it?
David,
On it's way.
Everyone else - I'll try to find a better file host. My ADSL line has very poor uplink speed so I'd appreciate it if any can identify a decent file host as Rapidshare seems to have a few problems. Took forever to upload this morning!
If you can't get it to work let me know. I can put in on our company's FTP server for a while.
Alan
"It's always fun to do the impossible." - Walt Disney
h
ht
Muthu
www.edison.co.in
with translation, of course ....
Muthu
www.edison.co.in
Muthu
www.edison.co.in
Please tell me you meant 6MB each and you haven't increased the size by 103.
Thanks to you and to Alan for the offer.
Muthu
www.edison.co.in
I'm hesitant to upload the book (or parts of it) because of copyright reasons. Also, a translation from German to English may be a bit time consuming. If there is enough interest, however, I'll design two example charts (one for hydro, one for turbo) and attach them to a post.
Wolf
Yes, I'd be interested in seeing them, especially if you can show the steps in producing them. I know a former colleague who would also be very interested although he's not a member here.
Betriebsverhalten der Synchronmaschine und Asynchronmaschine
http://w
Hi Scotty:
It will be my pleasure to give you this information. However, due to heavy work load, I've to ask for a little bit of patience.
Wolf
Hi folks:
Thanks for the patience.
Attached please find a method how to design a turbo generator (cylindrical rotor design) capability chart (Attachment I). It seems that it is not possible to place two attachments to one post. The second attachment will therefore be sent separately.
In case there is an interest, I can work out a capability chart design for a hydro generator (salient pole design) as well.
Best regards
Wolf
Folks:
Here is my second attachment.
Wolf
scotty, do you still have that CEGB document online? I tried the link but I guess the sharepoint is expired.
Wolf39, is the procedure your posted applicable to diesel generators and GTGs as well?
ThePunisher:
The procedure I issued is valid only for synchronous generators with cylindrical rotors. GTGs and fast running Diesel generators are falling into this category. Low speed Diesel generators with higher outputs, however, usually are equipped with salient poles, like hydro generators. To design a performance chart for this type of design is possible but more complicated. It seems that there is very little interest for such chart since there was no reaction expressed in the forum after I posted the other procedure last month.
Wolf
www.hydropower-consult.com
We have a large 3.74MW, 5.5MVA, 0.68 P.F. with a max kVAR = 4.45MVAR, 900RPM, Diesel generator. We have data for generator impendances and time constants. I am hoping you have something that couild help us at least construct this geenrator's capability curve since we are no longer able to contact the manufacturer for no apparent reason from the client.
ThePunisher:
If you read my posts carefully, you will find all the information you've asked for.
Wolf
http://ra
Sure this will be great info! Thanks wolf39 for the curve plot.
I for one have slow salient pole generators. From what I remember the difference between the files you uploaded (which are great by the way) is that there would be a difference in the underexcitation limit, since it could be running for a while with no (or reverse) excitation. If you have any info I that I would be interested.
If I remember my machine theory correctly a salient pole machine typically has a much greater capability to absorb reactive power than a turbo machine. I'd be interested in seeing how you develop a capability chart for a hydro machine, I haven't done much with salient pole machines because of the relative lack of hydro machines in the UK and I'd be interested to learn. Sorry if silence came across as dis-interest.
The underexcited zone becomes a question of bus voltage stability during the cap-curve test. The unit can run within a +/-5% variation of Vt for the given capability curve. Larger changes rescales the curve by the ratio of Vt/Xd against the base vector (Vt+IsxjXd = Ef)
Generally during underexcitation the stray flux tends to exit more perpendicular to the core laminations at the end-arms, hence the step back design of the top 3 and bottom 3 stator lamination stacks.
I've ran fully underexcited with good terminal voltage and with infra-red on a hydro, there were no heating concerns. In contrast, I have also ran another unit at ~ 70degrees rotor angle underexcited with a low bus voltage, and at that region a stability limit can exist.
UEL testing is the definitely the harder part of cap-curve testing.
