STEAM GENERATOR RELIEF VALVES
Hello all,
We are using a kettle type heat exchanger to produce steam from high temperature streams flowing in the tubes.
How many relief valves should be installed on the shell side (the steam produced side) which are in service at any time of operation and according to what code this is the demand?
roker
roker
RE: STEAM GENERATOR RELIEF VALVES
calculate btu/h and convert to pph to size your sv.
ASME IV FOR 15PSI STEAM AND I FOR HIGH PRESSURE
