Require help with Copper sheet flexing
Hello everyone,
I need help calculating the force required to bend a 99% pure copper sheet that is 40" X 40" x 12mm thick.  The sheet is secured at both ends.  It requires a 2" offset bend in the center.  The die used is a cup like shape which has a 4" radius.  The die is 40" long. Please help me with this one.   Attached is a little sketch if this helps.
