Roark's Flat Plate Equations vs. FEA... what's the deal?
6
I started a new topic since this one was closed:
http://www.eng-tips.com/viewthread.cfm?qid=171673&page=4
I'm looking at a flat plate that will be subjected to a pressure load.  The finite element model results were ~15% off of my hand calcs so I'm back to a simple case and I still can't figure it out.
Basic problem I'm looking at in Roark's:
10" x 12" x 0.125" thick steel plate
6.7 psi pressure load
All edges fixed
Roark's results:
stress along edge = 16440 psi
stress at center = 5943 psi
deflection = 0.016 in
MSC Nastran results:
14100 psi (14% off of Roark's)
6933 psi (16% off of Roark's)
0.021" (24% off of Roark's)
Nastran model was run with various mesh sizing, CQUAD4 elements, and all nodes along edges fixed in 123456 directions.
I don't think I'm violating any of the assumptions presented for these tables so why is there such a big difference in results?
I'm not a structural analyst by trade so sorry if I'm overlooking something simple.
RE: Roark's Flat Plate Equations vs. FEA... what's the deal?
4
I belive you are looking at von Mises stress.  The values from Roark are normal stresses in either the x or y directions (in the shorter direction of the rectangle).
yes... that works... and I feel a little stupid now. I knew it would be something simple.  :)
Thanks for the reply.
How about giving namklof a star since his/her response was helpful:
Just click on "Thank namklof for this valuable post!" under the post that was helpful.  Another screen will pop up to confirm.
It's a nice way of saying 'Thank you'.
That doesn't explain the difference in deflection though does it?
It's unusual to see an FEM softer than real world.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I get different values for the hand calculation.  I make the Roarke values:
ymax         -2.22E-02
Sig side    -16440.192
Sig cent    7692.672
Results from my FEA program (Strand7) were:
in the same order as above
4 node 12x10 grid
-2.35E-02    105.5%
-16370            99.6%
7788            101.2%
8 node 12x10
-2.30E-02    103.5%
-16190            98.5%
7686            99.9%
8 node 24x20
-2.301E-02    103.5%
-1.637E+04    99.6%
7.558E+03    98.2%
9 node 24x20
-2.301E-02    103.5%
-1.637E+04    99.6%
7.558E+03    98.2%
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
The Strand7 Verification Manual gives the following results for central deflection in a similar problem (square plate, clamped sides), using a 4x4 mesh of 1/4 of the plate with symmetrical boundary conditions:
Tri3:  -5.3%
Quad4  +4.7%
Tri6   -12%
Quad8  +0.48%
Quad9  +0.48%
So it seems the quad elements are a little softer than the analytical solution in this case.
Doug Jenkins
Linear FEM should be softer than real world because it ignores the membrane stiffness.
Cheers
Greg Locock
Greg - yes, but so does the analytical solution.  I don't recall the derivation of the equations for recangular plates, but I'd imagine they contain some fairly significant approximations.
Doug Jenkins
As I recall, the analytical solution by Roark also neglects transverse shear deformations which are included in the elements discussed.  If that is true, one could expect a well refined mesh to give slightly larger displacements, as noted by IDS.
Thanks IDS, Greg, & Namklof.
IDS, yes, there is a problem with my Roark's calculations posted above.  Not sure what I did, but what you posted is the correct deflection & center stress.
Did a little reading and have a rested mind so things are much clearer now.
Thanks again for the help.
