Customize Label on Parent for Detail View
NX 6.0.4.3 I have a detail view that I have cut from the sheet that the parent is on and pasted it on a 2nd sheet. Now, in the parent view label, I want to change the label from the standard "A" to say something like "A (SEE SHEET 2)" or "SEE DETAIL A ON SH 2". When I try to type this in the field it returns a "View letter is too Long" problem. And also I don't see a way to append text to the view label like you can on dimensions and other callouts. Any thoughts?
RE: Customize Label on Parent for Detail View
Also right click the annotation-prefix, you can change the value from "detail" to "See detail". That also should be available in customer defaults.
You can achieve what you asked for using edit text, which threatens to override the view dialog, but seems to do little actual harm. Possibly the better way to go though is to simply use the wording SEE SHT2 DETAIL A by editing the prefix in the way that NX actually supports best.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
