Apparent intersection point size
Thanks for your advice here, CBL. thread559-201967: Apparent Intersection
In a drawing when I create a point (Holding 2 edges)the, an apparent intersection point is formed. Is there a way to control the size of it. Its tooo big.
C1
RE: Apparent intersection point size
Have you tried changing the style of the Virtual Sharp?
Can you post a screen image of what you are seeing?
and so is your upload (3.5mb)...lol
You can try to adjust them in your document settings, though I don't know if you can change the size.  I have used the (*) in the past with good results.
[b] Go to Tools > Options > Document Properties > Drafting Standard > Virtual Sharps and maybe try the Plus or None options.
Thanks guys. This forum is so helpful. This is one of the reasons I like SolidWorks.
Sorry abt the heavy file. I dint bother to check before it uploading.
