limit assembly
limit assembly
limit assembly
Hi everyone !
I want to put in assy a linear limit.
Ex: I have a part with a travel of 12in. I want to put relation who'll limit the movement on my part from 0in to 12in.
Possible ??? with SE V18 ?
thank
RE: limit assembly
If there is an assembly relationship that governs this measurement then there will be a variable that defines its value. You may be able to define a range for this variable.
Look up 'Using Variables' in help
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
