ph netral phenolic foam
we are seeking a ph netral phenolic foam to use in a building panel product. As the frame is zinc coated steel it is perceived that we shpould find a non acidic foam to avoid corrosion.
The foam will be retained in an envelope and should not be subject to water other than a small amount of condensation. If anyone can shed some lite on this it would be greatly appreciated.
RE: ph netral phenolic foam
Dear Martinb
I spoke to Tahir Quraishi from Tiqsons Technologies Inc.
regarding your request for Phenolic pH neutral foam..
He suggested that more details are required as to application,quantity ..etc..
Tiqsons e-mail: tiqsons@tiqsons.com
Tel : 416 249 8101
Fax : 416 249 4505
They are representatives for various manufacturers and have access to expert opinion in the field..
Regards  Whylie
Whylie - many thanks for your response - will contact tiqsons@tiqsons.com and see what they can offer
Thanks and Regards
Martin Birch
