Motor Capacity Vs Load
Dear All
I am using 18 KW induction motor which draws 18 amps. at its load. What are the savings that I can gain if I used 11KW motor to run the same load.
Thank you
Sahan
Thank you
Sahan
RE: Motor Capacity Vs Load
Gunnar Englund
www.gke.org
This may not be true for all motors, but some it is.
So if you are under loading your motor, are you having power factor problems also?
Check out your current motor eff. If it is not a newer motor most likely you can save on operating expense by buying a high eff motor.
Of course you want your load to match the most eff curve of the motor.
I tell my operations elec guys to replace any older low effiecent motors (< 20 hp or so) with new higher eff ones, even if they are still working fine.
The size of the motor doesn't greatly effect the power draw. It is motor load determined, as long as they are approx the same size or motor.
By comparing eff you should be able to easily calculate the operational cost savings between two eff ratings.
W
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
