VFD Motor Load Reactor
For a 3ph, 5hp, 460V, motor a 1000ft from its VFD what do you suggest for protection from standing wave issues, a reactor?
For a line/load reactor (from MTE) I'm seeing numbers like $800!!!
Do I want a Line/Load reactor, or a sine wave motor protection filter? Or, a DV/DT Motor protection filter?
You can't just use an input reactor on the output can you?
Keith Cress
RE: VFD Motor Load Reactor
You might check with these guys also:
h
I'm pretty sure you don't need a sine wave filter. The DV/DT is the concern for long output leads.
AFAIK, the output reactors are pretty similar to the input reactors.
But I'm sure the experts will be along shortly.....
Dave
It seems a lot of reactor makers are saying that theirs can be applied to the input OR the output, calling them input/output reactors.
Of course I think I'd be fighting the dV/dT fight in this case which they don't seem to mention with the exception of MTE who makes "dV/dT filters". Which mysteriously enough, weight exactly the same 74lbs as the input/output reactors. Me thinks this is whole thing is just an exercise in label swapping.. :)
Keith Cress
For 5hp, 460V, 1000ft, and an MG1 P31 motor, I would expect a sine filter would be required. I have application data from MTE and TCI and, if I'm reading it right, that's the judgement from both.
1000ft motor leads is simply extreme length on a drive and, yes, the sine filter generally will cost about as much as the drive.
The only difference is a set of filter components (essentially snubber circuit) on a PC board, adds no weight.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I'm going to have them re-evaluate a DOL installation. Barring that, they need to go with the Full Monty $$$.
jraef; Thanks for that detail.
I learned something here, Thanks all.
Keith Cress
Nah, you just need a bigger hole or longer fingers....
I once did work in developing a submersible VFD for a company in Oregon called Selectric who made one that did fit down the hole with the motor. All they had coming back up the pipe was the power leads and a comm link for the operator interface. One of those great ideas in theory, not terribly practical in reality.
You need to communicate with the drive using carrier current so you don't need a highly problematic little cable for it, which has to add fragility and cost.
The VFD could be insanely small with the inherent water cooling.
Lets do it. :)
Keith Cress
Do not forget the voltage drop in the reactor/filter. It is an often missed factor and can lead to increased current demand if not factored in.
Neil
