Filler metal for 316/316LSS and Alloy 20
What filler metal should be used for 316/316L Stainless Steel to Alloy 20 welding (GTAW process)
Thanks a lot.
Thanks a lot.
RE: Filler metal for 316/316LSS and Alloy 20
However, since the weld needs no better corrosion resistance than 316 you could get away with simply using Alloy 20 weld filler.
Plymouth Tube
