Inter-rivet buckling
I'm performing some crippling analysis using Needham and need to compute some allowable inter-rivet buckling stress of some aluminum skin. The fasteners are countersunk tension head rivets and i planned on using L'/p = (2(2^.5)s)/t with the applicable column instability curve to get by allowable value. This would be fine with one row of rivets -but there are 2 rows of rivets (staggered) on this compression member. Does anyone know how to compute L'/p for 2 staggered rows of rivets?
RE: Inter-rivet buckling
With staggered rows, use the lengthwise spacing of each row to calculate Fir for each row unless the 1/2W calculated from the effective sheet width puts each row within the influence of the other (this will normally be the case). If so then use p=diagonal spacing between rivets to compute Fir.
Bear in mind that the whole deal is empirical.
Was the answer too conservative or did testing show that the panel buckled between fasteners prior to what was calculated?
