Seismic strength reduction in dry cemented sands?
I'm doing slope stability analyses on a small slope.  It's under a building and never gets wet.  No groundwater.  The soil is slightly cemented silty sand, phi=45, c=600.  The FSs are very high, as I knew they would be, but the County wants me to do the analyses, anyway.
The static FS is 6.5.  The seismic FS is 3.3, with c=600.  I was wondering if I should reduce c due to cyclic loading.  Are there any papers on the subject of cyclic loading on weakly cemented, dry sands?  I believe Nick Sitar at Cal wrote on this topic, but can't find the papers.
Just for fun, I ran the seismic analysis with c=50, and got a FS of 1.1.  But I think c should be much closer to the static value of 600.
RE: Seismic strength reduction in dry cemented sands?
try berkeley. i suggest you pay for membership. invaluable number of great papers available. i searched "cyclic cemented". good luck
http://nisee.berkeley.edu/elibrary/search
Both the phi and c values seem very high for a slightly cemented silty sand.  As a starting point, I would try using 80% of the static strength.  Try looking at the publication "recommended procedures for implementation of DMG special publication 117".  For this type of material, I would use the peak shear strength from a remolded sample (sample remolded to the in situ moisture and density).
I meant to say peak "drained" or "effective stress" strength.  The sample should be saturated during the test.
