Outputting G84.2 in post...
   I am trying to change the tapping cycle in my post to output G84.2 for rigid tapping as opposed to the default G84
   does anybody have any suggestions as to how to accomplish this?
   Thanks Beforehand!
RE: Outputting G84.2 in post...
You can set the option in the set parameters and then using this as a trigger you can change the block template that is used in PB or you might be able to just change the mom var that makes the 84 an 84.2. I have done this but it has been a while.
Everything I tried inside PB is making all my 'motion' G variables have decimals and I don't need that...
  Unless I'm missunderstanding you, I think changing the mom variable may be the way to go. I'm assuming I have to manually edit a file, but where do I find this file and what is it's name?
In Post builder you can create a new G word by selecting the existing G_motion and select create, this copies the existing G_motion
I renamed mine to G_motion_tap and then added the trailer as .2
Now you can edit the cycle to use the custom G word.
You will need to enable the editing of the tap cycle from the common parameters dialog.  Then you can remove the original G84 and add the new G_motion_tap word.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
NX5,6 Solid Works, Solid Edge
Awesome John!
   Thank you so much!
