Line Types and Solids not visible!
I'm working with AutoCAD 2005 and I'm working on an existing drawing. My problem is I'm back and forth in model space/paper space and when I go to either place I'm not see the different line types(every one appears to be continuous) and anything that has a solid fill is now just and outline. When I plot the drawing everything is plotted correctly, but this is a pain to work with because you're not sure what is what, and having to plot out the drawing just to look at lines and solids is a PAIN! I have other drawings, just as large and dealing with the model space/paper space thing and I have no problems. I'm pretty much guessing there is some toggle, switch, or value somewhere to "fix" this problem, I'm just not bright enough to know where to look! Any honchos out there that can help me?
RE: Line Types and Solids not visible!
