Pump Deadhead and Elevation
I have a pump question - somewhat embarrased to ask -- but I can't get a clear model in my mind.
What is is the relationship between a pump being deadhead and discharge pipe elevation?
Assume a centrifugal pump moving water out of a tank with level 10-ft above suction elevation.
Assume the suction and discharge pipe are large so that friction loss is low.
Assume the discharge head is 200-ft.
Assume a pressure gauge installed on the discharge line at 120-ft elevation.
The pressure gauge should read 200+10-120 = 90-ft.
Now assume there is a block valve just down stream of the pressure gauge.
Assume the block valve is shut.
The pump discharge head moves to 300-ft
Question: Does the gauge also read 300-ft ??
or does the gauge read 300+10-120 = 190-ft  ??
At deadhead, what is the impact of elevation ??
RE: Pump Deadhead and Elevation
The gauge does indeed read the pressure equivalent of 300+10-120 = 190 ft.
At deadhead, using the method you've used, which by the way is using a default reference elevation equal to the pump centerline elevation, is  no effect.
If you were to use a reference elevation of say nearest mean sea level, you would have a different equation, but still get the same answer.
Pump elevation is 1000 feet msl and the other dimensions remain the same...
therefore the equation is,
(1000+300) + (1000 + 10) - 120 = (1000 + 190)
You can see by simply subtracting the reference elevation from all terms, the equation is different, but nontheless equivalent, showing you can use whatever reference elevation is convenient.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
