importing 2d autocad files into proe
hi just started new job where as we have the task of converting a mountain of old aotocad drawing to 3d pro models is there any easy way of importing 2d dxf / dwg into proewildfire 2.0
RE: importing 2d autocad files into proe
File - Open and set the file type to (DWG/DXF)
Ben Loosli
There is also a capability to assist building 3D models from 2D data called AutobuildZ.  I have never used it.  In my experience, most AutoCAD data is too FUBAR to be useful, hopefully your experience will be different.
had played about with it to-day, when creating extrusion there is an option to import from file, you can then select a dwg format, had few problem but basically had to save back to an earlier version of autocad eventually got it sorted
