Need 270 VDC Aircraft Power Supply
Greetings All,
My job is going to be doing some design work on an electronic system going into an Aircraft utilizing a 270 VDC buss. Therefore, we need a 270 VDC power supply capable of about 40-50 amps for test bench work. Does anyone know of a vendor/manufacturer that is making a 270 VDC single voltage power supply capable of this amperage range? I know that Elgar makes a variable power supply that could output what I want but I'm hoping that someone out there makes an off the shelf single voltage power supply with my desired voltage/amperage range.
Thanx!
Gordon
