Mechanical testing of notched specimens
Hi there,
I am currently testing a certain metal in a notched tensile test piece and standard dog-bone/straight test piece. The notched test piece average ultimate stress is HIGHER than the straight test piece ultimate stress. Any reasons for this? I thought the notch would act as a stress-raiser and produce lower results?
Thanks very much,
Dave
Thanks very much,
Dave
RE: Mechanical testing of notched specimens
Well, assumming your tensile test procedure and specimen geometry were in accordance with ASTM E8 and this certain metal (which you have not identified) exhibits work hardening and lower notch sensitivity characteristics; these factors alone could result in a ratio of notched/smooth bar tensile test values greater than 1.0.
You really would need to provide more information for a definitive answer. Also, you might be interested in reading the excerpt below
http://
Good info, thanks for that. It's MP35N, the mother-of-all steels as far as I can tell. It's got ridiculous properties, but is apparently a good 25% stronger as a notched specimen.
Thanks again,
Dave
http
Because it has no Fe, is that why the tri-axial stress concentration strengthens it? Is the strengthening phenomonon of tri-axial stress only applicable to some non-Fe materials?
Thanks again,
Dave
No, the phenomenon of notch strengthening (also called notch ductility) applies to many different metals, including Fe-, Ni-, Al-, and Ti-based alloys. It is dependent upon the microstructure, not the predominant atomic species. Perform a Google search of "notch ductility" or "notch strengthening" and you will find more references on the subject. Here is one short article that shows some relative rankings of various alloys:
http://ww
