transverse shear stiffness
Dear all,
Is it necessary to use transverse shear stiffness whenever using shell section card? I can see that most of examples do not include.
Do the k values in transverse shear stiffness correspond to the material's young's modulus? If not, how can i calculate it?
By the way, Im using S4R and SC8R.
Minki
RE: transverse shear stiffness
Depends what you are modeling.  For an isotropic metal plate, transverse shear flexibility is usually negligible.  For a composite sandwich panel, transverse shear flexibility is usually significant.  The K factor is probably the transverse shear shape factor, which is a function of geometry and material properties (see Roark)
