Is there a way to Pack all packable components in Assembly Navigator?
NX6.0.3
For assemblies with large numbers of repeated components (such as fasteners, etc), it's often helpful to simplify the Assembly Navigator tree by right clicking on a repeated component, and selecting "Pack".
However, if you close the assembly and then re-open, the ANT is un-packed.  I'm pretty sure there's no way to "save" the packed or un-packed configuration.  But, I'm wondering if there could be a way to write a macro or some other method such that upon invoking this custom command, all "pack-able" components would be packed in the assembly tree?  This would make a quick way to rapidly clean up the assembly tree.
It'd be useful to create a custom command like this (and ideally assign it to an icon or something similar, so it's easy to run when desired).  Unfortunately, I'm not sure where to start on this, so it'd be great to hear from some more skilled NX automation experts.
Thanks.
RE: Is there a way to Pack all packable components in Assembly Navigator?
Why not just place your cursor over some 'white space' in the Assembly Navigator, press MB3 and select the 'Pack All' option:
Or you could just go into Customize select the 'Keyboard' option, select the Category 'Assembly Navigator', then from the list of 'Commands', select 'Pack All' and assign a hot-key sequence, perhaps something like Ctrl+Alt+P.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Just one addition to John's advice: you will probably have to 'expand all' then 'pack all' to catch all the packable components.
Wow, how have I completely missed this.  That's everything I was asking for. Thanks.
