Extract applied pressures on pipe element from output database?
Hello evevyone,
I am looking for how I can extract from the output database, with python, the pressures I applied on pipe elements. I have not found any output variable (P is only valid for solid and shell element) and I need to have access to those data in order to implement an automatic design check which is based on the applied internal and extrenal pressures. Regarding the applied temperature it is ok because you can output for each element the variable 'TEMP'.
Please, Does anybody would be kind to help me as soon as possible?
Thanks in advance.
Thanks in advance.
